Johnson spider cone: Myriad issues http://www-.luthiersforum.com/forum/viewtopic.php?f=10104&t=45058 |
Author: | Freeman [ Thu Feb 19, 2015 11:54 am ] |
Post subject: | Re: Johnson spider cone: Myriad issues |
Can't see the pictures. One of my favorite guitars is a 1932 Dobro that had been spray painted black. When I got it the cone and cover plate was crushed, binding coming off in strips and otherwise a pretty bad mess. I didn't know if I could fix it but I gave two hundred dollars to the lady who owned it. She said her father had bought it when she was a child. When it was done I took it back and played it for her - I didn't play very well but she wept. ![]() Lets fix yours. |
Author: | Dancin Dan [ Thu Feb 19, 2015 12:42 pm ] |
Must have moved the pics in my photobucket. Started with this: ![]() ![]() ![]() |
Author: | Freeman [ Thu Feb 19, 2015 1:46 pm ] |
Can't tell from your pics but most resonators have a neck stick rather than a conventional dovetail or bolted joint. I'm guessing yours doesn't - there would be a little shim block on the back of the guitar that the neck bolts to. They also have one or more screws thru the fretboard extension which holds it down to the top - they are normally hidden my the fretboard markers (feel around under the top and see if there is a bolt or two). Good luck |
Author: | Dancin Dan [ Thu Feb 19, 2015 4:00 pm ] |
I hope to have a little free time this weekend to mess with this one. I'll poke around and see if that's the case. |
Author: | Dancin Dan [ Thu Feb 19, 2015 6:16 pm ] |
The outer ring that looks like a crack is just dust & grime that settled under the lip of the hot glue. ![]() As it sits currently. ![]() |
Author: | Dancin Dan [ Fri Feb 20, 2015 6:39 pm ] |
Pulled the tuning pegs (tuning machines?) right after work today. Then I got around to uncovering the soundholes. Hand to God, I swear this stuff has to be caulk of some kind. Is there a legit style of glue used in luthiery that behaves just like white silicone caulk? ![]() |
